Pink bands
    Pink bands
    What is causing this?!?!
    Re: Pink bands
    bump
      Re: Pink bands
      Model number of the TV would help
        Re: Pink bands
        sorry its a pn51e530
          Re: Pink bands
          Ok new observations. Now when i pull up adjustement menu and turn down cell and turn it back up it stops but when it switches to another commercial with brright back gound it starts. Already tried vs adjustements and reseated ribbon cables on on each side of screen and t-con. Its like it resets. This also affects the menu.Main board? t-con? power supply? y sus? x sus?
            Re: Pink bands
            Not power supply board or panel because test pattern displays white and it stops doing it like something has been disconnected. Leaves t-con, main, logic and x sus y sus
              Re: Pink bands
              Aged/old/worn plasma-panel.
              Sometimes you can cover it up by increasing the Vs about 5-10v, but the prob will return in time.
              TELEFIX
                Re: Pink bands
                As Alastair says. Try to increase the Vs voltage. You need to measure it so you wont inmediately go 20V up.
                The potmeters are on the Ysus board , maybe a little tweak on the Zsus board also helps. Last one helpt me on a old panasonic plasma. White was more green , i turned up the Zsus and it was gone.
                  Re: Pink bands
                  after 3 yearrs?
                    Re: Pink bands
                    y and z on one board for my model
                      Re: Pink bands
                      Can you post a picture of that board? Try to make it as clear as possible so we can tell you which pot meter you need to alter.
                        Re: Pink bands
                        Originally posted by hotcoffee View Post
                        after 3 yearrs?
                        Certainly!
                        Ive seen many a Samsung with a dodgy PDP, and Always the Newer ones, while the old duffers go on forever!
                        TELEFIX
                          Re: Pink bands
                          like this?
                            Re: Pink bands
                            update turns out it was power supply all along!! thanks to all
