List of Bad Cap Manufacturers
This is a sticky topic.
    Re: List of Bad Cap Manufacturers
    Spotted these in a cheap 19V "3.42A"chinese laptop power brick. WXD and Acon. WXD might be the series, but that's all I could find written on them without pulling them. Look at this build quality....However, the customer brought it in looking like this, already cracked open and held together by a rubber band. Maybe he messed with it.
      ^ Yeah, I think he definitely messed with it. Small custom size PCBs are cheap in China, so if this mod/hack was to be done by the factory, they most likely would have used a small, but properly cut board for the job.
        Yungli capacitors
        "Yungli" As you can guess, their capacitance isn't 1000uF. Not even close! I was guessing ~680uF at worst. They read 524uF and 533uF
          It would be interesting to cut 'em open. I wonder how big the rolls are...
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
            The logo seems to imitate L-tec/Lelon a little bit. They look a bit small for 1000 uF @ 200V. What size were they? Lol, it's funny they are not even 560 uF... but I guess if you take the +/-20%, they are .
              Hi folks. What can you say about Zeasset aka ZSTE caps? I've found them in a Chinese domestic market welding machine, input filter.
              Sorry if offtop.
                Also, there are some "TL" (http://capacitor.web.fc2.com/t.html#tl).
                  nice link.
                    I have some interesting info about TL. The full name is Jiangxi Telexon, and it is a subsidiary of Man Yue, maybe an OEM supplier for Samxon. http://www.tl4321.com
                    Also, there is a legend that their products are used in military and aerospace tech.
                    UPD: Oh, I see you already have its datasheets. So, add also sheets from zeasset.com, maybe someone will find ZSTE in some chinese fleamarketware.
                      TLs are CD81 and CD110 series, BTW.
                        Can't remember the make though, but I'm reminded of a few years when back I came across some caps who's capacitance was not even close to what it said on the outside of the can. Opened the can up and it was empty inside, except for a tiny ass cap soldered in at the botton. Sneaky bastards
                          Had a sift through the pile of "dead bits" in the office today
                          One dead Dell 745 and one dead GX620
                          The 745 looked perfect motherboard wise, power light was on but nothing when power button pressed.
                          So in the PSU I delved, loads of crusty caps
                          - Ltech? 2200uf 10v LZP's, Ltech 1500uf 10v LXY's and a Ltech 680uf 16v LXY
                          The GX620 was easy to diagnose, all 4 caps around the 12v CPU power are mega crusty 1800uf 6.3v KZJ's
                          No real need to fix them but have ordered the caps because they will only end up on the tip otherwise and are both quite serviceable machines.
                            Hitachi HP3 85C 390uf 400v
                            PSU=> IN-WIN Commander 1500
                              Got one, rudoycon. Makes a better resistror than cap. 27pF, ESR retarded high!
                              Follow the white rabbit.
                                LOL, I've seen that brand before. I figured they were garbage XD
                                Did you take it apart? Is it really lightweight? I wonder what it's like inside. 27pF? ... That's like REALLY crap XD
                                -Ben
                                Muh-soggy-knee
                                  I don't think you should blame the caps...
                                  ltec LZP are 2000-4000h Lifetime ones, with the 10mm diametre ones with just 3000h lifetime.
                                  That LXY is a tad better than LZP with 2000-5000h Lifetime, but the cap you mentioned is also smaller, so nothing won, also 3000h Lifetime...
                                  Here their datasheets with specs...
                                  http://www.ltec.com.tw/product_e.html
                                  So you can't blame the cap for failing at all...
                                  Because it lasted according to their specifications.
                                  If you want to blame someone, pls blame DELL (or whoever made that PSU) for using cheapish caps instead of more reliable ones...
                                  Using 10mm or more caps on the secondary side helps a lot...
                                  Also using better series like LZF (5-8kh) or LXU...
                                  With using something specified for 2000 or 3000h failing after a couple of years is something you'd expect...
                                    ^^Yes yes, must be something else than the caps.
                                    I mean Ltec, Teapo, CapXon and your other favorite brands they never lied in the specification sheets.
                                    And their quality is always comparable with the 5 major Japanese brands.
                                    Let's all blame the heatsink, or the cable blocking the airflow, or the choice of Pi filters.
                                    Remark: there is some possibility that the above text was meant to be ironic.
                                    Edit: Quick Google search:
                                    https://www.badcaps.net/forum/showthread.php?t=27655
                                    https://www.badcaps.net/forum/showthread.php?t=33442
                                      Right, it's not the caps fault for failing.
                                      It's whoever used such 'low spec caps' in the first place who's to blame.
                                      Take a look at the link I posted...
                                      LZP is the second from the top.
                                      LXY is the first of those 'ultra low ESR' caps.
                                      The List seems to be in that order that the worst caps of a category are on the top.
                                      Also the best ones of that category are under those...
                                      So with this info, we know that whoever made this PSU used the worst ltec caps there are...
                                      Of course they would fail sooner than later...
                                      And of course they fail sooner than japanese capacitors. Because japanese companys don't make such low end capacitors! (well, besides Nichicon UPS series maybe)...
                                      The buttom line is:
                                      If they used better caps, even if they are from ltec, they would have lasted longer.
                                      BUT: They would also have cost more.
                                      And that's the point...
                                      Don't blame the cap maker for the shit the one soldering the caps down is responsible...
                                      And for the 5 major japanese brands:
                                      They don't make such low spec/quality caps no more...
                                      Well, besides Nichicon UPS series, wich seem to be really shitty (look at the datasheet and compare them to Teapo SC)...
                                      And now we are at the 'you get what you paid for' point...
                                      If you want better quality, you have to pay more.
                                      If you want less quality, you don't have to pay as much...
                                      So you shoudn't blame ltec for whoever made this PSU cheapening out on caps...
                                      It's their fault those caps bulged...
                                      Well, at least in this case it's pretty obvious, don't you think?
                                      PS: PLS stop talking about cap makers and start talking about cap series.
                                      Like the ltec LXY & LZP aren't good. That's something I'd agree on.
                                      Also when you'd say Teapo SC and SZ don't last that long. Nothing to disagree here either.
                                      But: Every half way decent cap manufacturer has better series than that in their cataloges and also something that's on par with the 'japanese' capacitors...
                                      For Teapo that would be TA, TB, TC or ST, depending on what you want...
                                      All 4 are up to 10.000h lifetime...
                                      And also some PSU manufacturers say, that the manufacturers matter not.
                                      But what you are willing to pay (and what you want).
                                      Here someone wantet cheapish capacitors and got them...
                                        I'm not blaming Ltec, Teapo or CapXon.
                                        I'm blaming the PSU manufacturers that use such shitty crap in their high end designs.
                                        And people who seem hell bent on promoting that there is nothing wrong in doing so.
                                        "Because the spec sheets say it will last for XXX amount of time"
                                        -Guess what, Fuhjyyu TM has a datasheet too, but it does not say that the caps will fail within one year at room temperature but they do.
                                        Then we get fantastic representatives from PSU companies coming here explaining to us how their fantastic PSU's are so great and never fail, and if they do it's absolutely not the Fuhjyyu's fault.
                                        Maybe you should read up a bit on PSU design and you would understand why they use capacitors closer to general purpose than ultra low ESR.
                                        https://www.badcaps.net/forum/showth...5911#post25911
                                          @ Stefan Payne: you need to read up more about capacitor lifetime. Actually, many datasheets call it endurance time/rating - and for a good reason.
                                          In short, the endurance rating just tells you how many hours you can abuse the cap and still have it perform in spec. It's basically a guarantee of the minimum lifetime the capacitor will have when stressed @ maximum rated temperature, maximum ripple current, and at maximum rated voltage applied. See this:
                                          https://www.badcaps.net/forum/showthread.php?t=28479
                                          Thus, a 105C-rated capacitor with an endurance rating of 2000 hours should still be in spec after 2000 hours @ 105C operating temperature, with maximum ripple current and maximum rated voltage applied. This does not necessarily mean that the capacitor will fail right away afterwards - no, the capacitor could last much more. But the endurance rating is the lifetime the manufacturer says the cap will do for sure.
                                          Also, it is commonly accepted that the capacitor lifetime approximately doubles for every decade drop in temperature below the rated maximum. Thus, at 65C (typical temperature inside an LCD monitor, from what I've measured), the same 2000-hour 105C capacitor mentioned above should last at least
                                          2^((105-65)/10) x 2000 hours = (2^4) x 2000 = 32000 hours = about 3.6 years minimum.
                                          Now the sad part is that many CN/TW capacitors will not hold their ratings and usually fail within a much shorter period of time, regardless of the running temperature. That's what makes those cheap caps bad - you just don't know when and why they will fail. So in regards to Per Hansson comment about Fuhjyyu TM: well, I have some Fuhjyyu TM, TMR, and TNR that have all lasted many many years and are still in spec. But I've also seen ones that appeared to fail without much abuse. So the conclusion is, cheap caps are unreliable and their specs should not be trusted.
                                          So yes, we really can (or at least, should) blame crappy cap manufacturers for their early failures. And yes, we can also blame PSU manufactuers for not using better brand of capacitors. But I don't think using a "higher"-end series from a cheap manufacturer will do much good.
