sony kdl-46w5500 t-con
    hey all, im trying to find a part number for an ic on a sony lj94-02642j t-con board.
    ic21
    it had a slight failure :/
    thanks heaps!
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    Re: sony kdl-46w5500 t-con
    Can you by any chance elaborate what kind of failure?
    Since yesterday I've been facing a problem of horizontal black stripes of pixels on the same TV.
    Thanks.
      Horizontal black stripes? How many and how broad are they? Could be a panel failure.
        Sorry for the late response, I was out of the country.
        The stripes start from the right side of the panel and span around 30% horizontally.
        They start black from the right side and gradually retain their intended color.
        The stripes are every 6th line of pixels.
        The stripes are only 1 pixel high.
        I would have posted an image, but not sure if these details will be clear from my photo.
        Thanks for your reply.
        Sinan.
          I tried uploading a photo of the right top corner, I hope this clears things up a bit.
            hi sinan if you press menu do you see the menu display in the lines?
              The menu is also affected - so I see the lines over the menu and not only over HDMI or tuner content.
                If the menu is affected its probably 9/10 the panel itself. I have a Samsung doing this and its a bad panel and it will only get worse.
                  Oh... That really leaves no hope for fixing it right?
