I have to ask for some help on this one. While I realize Polaroid TVs are not first rate, I need to understand what's going on with it. I can't find a schematic but from my understanding, the only voltage from the PSU is 24v. I have 24v until I plug the main board in. Then the voltage goes to around 1v to the inverter and 16v at the main board. This happens whether the turn on voltage from the main board (4.9v) is used or if I turn it on with a resistor. There is no voltage on the inverter turn on pin.
I thought the main board was pulling down the PSU so I ordered a pullout board even though all the regulator voltages and caps on the board were good. No help.
Could the PSU be supplying 24v but with too little current? All the caps have normal ESR. They're all Nichicons! My only other clue is that the voltage on the main cap is around 180. I would think it should be higher in a supply with PFC. I know these PSUs are not particularly reliable but I have an emotional need to fix it now. It's ticking me off.
Any help would be very much appreciated.
