I got a Vizio TV that has no power. When you connect the power cable, nothing happens. You press the power button on the remote, nothing, you press the power button on the side of the TV, nothing.
I checked the fuse (15A 250V) and there is continuity. I also checked thermistor (has a stamp of 2r55a) as well as the film capacitor (.33k275V), and I'm getting a reading. I also check for voltage going to the fuse and there is a voltage reading. I also checked the resistors based on their value and they are OK. I also checked the two capacitors 470mf 35v and their reading is correct, but when I check the middle capacitor (the long brown one), I do not get any reading with power or w/out power.
Anything else I'm missing that you guys can help me? Perhaps I might need someone to show me to test voltage after the fuse. I'm not too experienced when it comes to electronics.
Pictures attached
https://www.badcaps.net/forum/attach...1&d=1406095100
Thank you.
Pictures attached
Thank you.
