Re: Polaroid FLM323 Blue led, no video
24vstby to the PS_ON pin using 5K (as I indicated, the wire on the PS_ON must be disconnected) as you have done before in post1 to turn on the switched 24V. The voltage of that main filter cap should jump up to 370~400VDC when PFC circuit kick in, the switched 24V will then turn on and supply the 24V to the inverter board. You also indicated that you do have BL_ON signal so the backlights should come on.
Now to be sure about the 24VSTBY, that should stay at 24V since it used by the main board to run, if that voltage does not stay at 24V then your 24Vstby power supply section is not working right. Just remember that you have 24vstby power supply for the main board and another switched power supply for running the inverter board.
Now after reading your post 1 many time, I see that you only see 16V feeding the the main board instead of 24V (at that time I did not know for sure that your power supply has 24vstby instead of typical 5vstby until I found my pictures of your power supply board)
