4 Ports HDMI 1x4 Powered Splitter help.
    HI guys i need to buy a reliable 4 Ports HDMI 1x4 Powered Splitter Ver 1.3 Certified for Full HD 1080P,
    so my setup will be Output HDMI signal from MINIX NEO U9-H, 64-bit Octa-Core Media Hub for Android,to the 1x4 Sp-liter and connect to a 1080P Led VIZIO TV and a 1080P Phillips LCD TV and then connect also on the third port a 1080P HDMI to Composite video converter adapter;Tendak 1080P HDMI to AV 3RCA CVBs Composite Video Audio Converter Adapter,that i want to connect to my Old tube TVs that will be connected to this 1080P converter to Composite video,then from the RCA composite adapter i send the signal to a RF {radio frequency} converter throughout coaxial cable to the whole house.
    At present time i have a manual push button switch 1x2 connected with 1 TV and the 1080P to Composite video adapter and it's working great but i have to switch outputs manually every time i want to watch another TV, wish you guys build one like this 1x3 push button manually,i wouldn't mind at all see pic. Sewell Direct Ibis - 2x1 or 1x2 HDMI Bi-Directional Switch with HDCP Passthrough, 3D and 1080p Support,any insight on this from you experts,thanks
    Re: 4 Ports HDMI 1x4 Powered Splitter help.
    you dont need a switch, that's for multiple inputs.
    you need a distribution-splitter with multiple buffered outputs.
    electronically speaking, there is no magic there - i would be surprised if the chinese didnt have a few on ebay.
    i know they used to sell vga versions for driving multiple monitors from a single pc for shops / demonstation setups.
      just checked - fuckloads of them!!
      go on ebay, the magic search term is "4 port hdmi splitter"
        Thanks guys i just ordered this one, hope it'll work ?if not i'll return it like the previous one,amazon is five stars with returns.
        https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
          $50???
          the chinese would sell you one for about $15!!!
            $50???
            But i want something that works and has support and warrenty,i bought the chiper one prier to this one and it was no good,this one seems to be better,i hope.i never had lucky with the cheap ones.
              where do you think the $50 one is made!
                China.
                  Hi guys i just received this HDMI Splitter and i must say that is the best Splitter i ever have,it send video to my 4 tv Displays without a hitch.
                    When you have all 4 displays connected and running, does it adjust ALL the outputs to lowest resolution based on the display with the least capability?
                      Yes ,if you have for example, as i have 3 1080P tvs and 1 720p tv,,if all are turned on at same time , yes it goes the to the lower resolution on all of them,but if you turn off the tv with 720P the others 1080P will go back to 1080P.
