BL ON steady? Check voltage across large 450V capacitor(s) on PSU.
Green or brown wires going to inverter. One is BLON and the other is DIM.
370V is a little low; does it drop when flickering?
It can be hard to tell if it is PSU or inverter. In my opinion it's a lot more likely to be PSU, but this isn't always the case.
What I would suggest is attaching two car headlamps, in series, to the 24V output. If you're short of them, Poundland sell them in packs of two (they're probably rubbish, but they're OK for a 65W load.) This will provide approx 65W load to the PSU, around 1/2 what the inverter draws. If that flickers, the PSU has an issue. You can also try adding a second set providing 130W if it does not flicker. 130W is about right for a fully functioning 32" inverter.
The 370V PFC sounds low to me, if I were to focus on any particular area. Does that rise with the inverter disconnected?
Hi i have just repaired one of these this week the BLon comes out of the bottom of the Av board to the inverter. This set would not turn the backlight on and would not turn off to standby with side buttons or remote it was the 3.3 v regulator on the Av board in the bottom left corner second one up easy fix
No not that one the one above marked 1117 33 you need to check for 3.3v on the center leg or the tab (north)i would check all the regulators as they seem to feed each other,all the rest are adjustable regulators so take a reading of all three legs 1/2/3 with the tab (north)up,reading 1/2/3 from left to right a good reg will read 1.25v higher on leg 2 then leg 1,so if leg 1 reads 1.5v leg 2 should be 2.75v, there are lots on here on how to test regulators just do a search.
Narrow the problem down. If you have steady BLON and DIM, then the main board shouldn't cause the flickering. Note: I forgot to mention to check PSON. It'd be a good idea to check that too.
ok measurements in picture attached this tv is really intermittent now the backlight stays on but i can turn the tv On via remote or side button,but when i try to turn it off via remote or side button i have to switch it of via the mains switch
Middle most regulator, was pin #1 jumping around? That reading is odd, comparing to pin #2.
now i cant give you that answer because i have just turned the tv back on and im now back to a flashing backlight and all regulator pins are now fluctuating
