Re: Vizio VX32L turns on with backlight, no video or sound
OK, so I'm rereading posts, have new adjustable regulators on order (to replace the wrong AP1117E18 fixed voltage regulators I put in ). Not much to do until I get those parts replaced, but attached are a series of photos of the main board.
To summarize:
Problem: Vizio VX32L (2007) TV powers on, backlight is on, but no sound, no picture, and only way to turn TV off is unplug. All other controls are unresponsive (both remote and the buttons).
Inspected/Tested/Tried:
No visible caps blown, no other smoked components seen/smelled.
reseated cables/ribbons
tested fuses on main board OK (0 ohms), 5V on one, 12V on the other
Tested outputs from power supply- 5V, 12V, and 24V all present in appropriate places.
Tested fuse on T-con board(?) (at top under a bunch of metal), 0 ohms.
IC Top Mid Bottom
U7 3.3, 1.8, 0 (after I replaced with the wrong regulator!)
U9 is 3.3, 2.2, 0.4 (after I replaced with the wrong regulator!)
U8 is 5.1, 3.3, 2.0
U33 5.0 3.35 2.1
U2 5.1 3.3 2.0
U4 5.1 3.3 2.1
U15 5.15 in , 5.05 out
Status:
Waiting until correct regulators come. Is there anything else I should be testing while I'm waiting? Is it likely I cooked something else putting in the wrong regulators, in which case I should look for a new main board?
To summarize:
IC Top Mid Bottom
U8 is 5.1, 3.3, 2.0
U33 5.0 3.35 2.1
U2 5.1 3.3 2.0
U4 5.1 3.3 2.1
Status:
