Toshiba Satellite L655 (HannStar J MV-4 94V-0)
    Hi, i got this notebook with no power led on. I assume that the power jack is bad but jack is fine. i got 19V on board, but no sign of power when i press power switch. Can someone help?
    ...the quieter you become the more you are able to hear...
    Re: Toshiba Satellite L655 (HannStar J MV-4 94V-0)
    i test all fuse they are OK
      when push start button on battery, orange LED (battery empty) blink, and that is it, no charging LED and no power LED
        first of all find the schematic. start measuring voltages in power circuit mosfets. But you also need to measure the current.
          Hmm how can i measure current on mosfets?
            not mosfets but entire circuit. To solve motherboard faults, you need an adjustble regulated power supply unit with current meter.
              i found in this thread the same problem, i think here is bad MAX17435ETG+ Battery Management High f SMBus. And i found the schematic od mobo. So there is no power, all led-s are dead except blinking orange (like battery low). What do you think?
                i replace MAX17435ETG+, but still no power , i check L6000 now its 0V.
                  i don't see that any voltages other than 1V are going into the U6000 IC, i have 12V on one side of Q6002 and other side is 0.86V.
                    i had a toshiba satellite like this and when i place the ram in a wrong possition the led blink and no power.
                      I dont thin this is the same issue. Notebook wont charge at all, with ram or not
                        where are the other pages of the scheme?
                        did you see that 24v dc input? do you have a 24v ps for this notebook? :O
                          No, i have 19V ps (standard notebook charger)
                            If there is 12v on the Drain of Q6002, it should be 19v from the charger. Why is it only 12v?
                            Or is the 12v on the Source from the battery?
                              Firts battery OFF, AC ON.
                              Measure Q6002 all PIN.
                                If you have 12v on one side of Q6002, (I think it comes from battery) probably D6005 or L6001 (from 19v side) could be open. Check it and post.
                                Cheers.
                                  one side that come from adapter is 0.56V, and other side is 0V
                                    this is without battery
                                      Ok. There is no AC voltage.
                                      Measure L6001 PIN1, PIN2 and D6005 PIN1, PIN3.
                                        L6001 PIN 1 and PIN 2 =19V, D6005 PIN1 and PIN2 = 19V
