HP f2105
    HP f2105
    Hi all got a small problem with my 21" hp monitor
    First thought inverter board had a bad transformer as there are three to run 6 lamps but they all tested ok so next suspected lamps bingo middle two (which i have circled in yellow) not working or maybe just one of the two as i connected 2 lamps externally and screen worked fine on 4 lamps with an adjustment to the brightness .
    I know i will have to replace one top and one bottom to balance it out but until i have sorted out another monitor so i can fully strip it down to measure bulb length and replace i have heard i can use a resistor across the connections to make monitor run .
    My questions are 1 is it possible and 2 if so what size resistor should i use ,
    this would only be a temp measure until i get sorted .
    Any input welcome thanks in advance
    Re: HP f2105
    If I understand this correctly, see
    https://www.badcaps.net/forum/showth...=resistor+fool
    --- begin sig file ---
    --- end sig file ---
      Re: HP f2105
      Hi thanks for that thought i had heard or read it somewhere .
      Now just gotta check out my stock and see if i have 2resistors that size .
      Will let you know what happens
      Then again if you dont hear from me
        Re: HP f2105
        bad power button board i am sure of it.....i just fixed mine found the answer on cnet forums i thought it was an inverter too but its not...
          Re: HP f2105
          This model is know for having bad lamps (fixed 3 of them), easily broken plastic hinge for the power switch ( fixed 4 of these using RTV to fix the hinge), bad LCD panel (vertical lines). But it does have good pictures when it works.
            Re: HP f2105
            RTV being ??/to us uneducated English people !!
              Re: HP f2105
              Full term: Room Temperature Vulcanizing Silicone or Sealant.
                Re: HP f2105
                Ta muchly.
                  Re: HP f2105
                  Hi Rtech
                  Mine turned out to be the lamps on top of the screen had rotted the earth cables so i picked up another that had a good screen and lamps and swapped them over .
                  So if you need any spares i have a working psu ,inverter and main board in fact i have the whole unit minus the screen and power button as it was broken plus a stand
