Noob to the forum. I've read dozens of threads on this unit and looking for some advice on repairing my TV. I've taken the entire TV apart, down to separating the LCD from the backlight.
System Info:
-LC420WU5
-Master Inverter: 6632L-0470A PNEL-T707A REV-1.2
-Slave Inverter: 6632L-0471A PNEL-T708A REV-1.2
Symptoms:
- Backlight goes off ~2 seconds after powering on
Observations:
- Blue LED on Master Inverter lights up when powering on, then fades to off, just as the backlight shuts off.
- The area of the backlights toward the side of the Slave Inverter appear to be dimmer than the side toward the Master Inverter. But it is hard to be definitive on this observation because it shuts off too quickly.
- Audio is OK even after backlight goes off. Test is using HDMI-2 input
- LCD image OK. [I put a high-powered light behind LCD and image is just fine]
- CCFL tubes all appear to not have any dark spots. All white, consistent across all tubes.
- Both inverter boards are pristine. No bulging caps, fried ICs, traces, or any obvious burn marks on either side of both boards.
- Power supply board does not appear to have any burn marks, bulging caps, fried traces, or other obvious damage on either the component or trace side.
Questions:
- What other tests should I perform, if any, to get a more precise diagnosis?
I do have a DMM, fine-tip and standard soldering equipment. Also have access to scopes, desoldering equipment, etc. at work.
Thanks for any advice. Hope this helps others as well.
System Info:
-LC420WU5
Symptoms:
Observations:
Questions:
