Hey all
I just found this site - read part of the FAQ - all i can say is WOW - i never realized that a failed cap is such a big possible reason why computer related equipment could fail!
Here's the scoop - 2 or 3 years ago - i forget exactly how long ago - I was working for radioshack - and finally convinced my mom to buy a wireless router. I had heard such rave reviews about this new WRT54G router - and i have had linksys routers/nic's before - and never had problems with them. So we bought a wrt54G - this was one of the first versions - i think it even came with firmware release version like 1.05 or something.
Anyway - it worked great for years - one day my mom calls me (i moved out so now i can provide only phone tech support most of the time) - and says the internet is down. After several days of calls with her - i finally stop by and check it out - the router is the cause - no lights were on - i would unplug it - and plug it in - a light or two would flash and then go off. Nothing would happen besides that
My mom ended up going out and buying a replacement wrt54G - but i still had the dead one.
now, a few months later - i'm moving into a new and bigger house - and found the dead wrt54g - i pluged it in and now nothing happens. I decided to pull it appart - and see if i could see any dead components.
Nothing visible - so i pluged it in to see if i could use my multimeter to trace the voltage and see if it was getting juice.
First thing i heard - was a very low hissing/electrical-buzz noise. It was comming from somewhere near the inductor / 2 capacitors.
well both caps are the same size - 16 volt 1000uF
I am a college kid with very little circuit training (took a boolean logic class, and i build home theater systems for fun - including the crossovers, but thats about the extent of my knowledge on electrical circuits) - but using my multimeter - i discovered that the two capacitors had very differant voltage readings (unpluged the power supply of course)
I tested the resistance and amperage. Now obviously i should have used some better methods of testing - but i suspect that since the noise was comming from the two caps - and the board is pretty empty in that area of the noise except for the inductor and 2 caps. I'm pretty sure that its a cap.
I'm going to go to radioshack and pick up some replacements caps, and replace them - if it doesn't work - no worries. I read up on how to desolder and replace the caps - no worries on that end - i've done plenty of soldering in my time (like i said - i build various types of crossovers for my audio systems) - but i'm just concerned about what caps to get.
I don't care if they are low quality - since the firmware will be upgraded to a tibor (hyperwrt) os so i can use it as a wireless repeater to extend the coverage of my wifi for the house (i have 2 laptops and am building an HTPC that will have wireless access to my media server)
I thought i read somethign about using a higher voltage is ok for capacitors correct?
If i can't find 16volt 1000uF locally (no sense in buying some caps online to fix somethign worth $20 tops - and spending $5 in shipping) - what should i do - i have enough space to rig up caps in series/parallel to make it get 1000uF - but voltage is the biggest concern.
Thanks for the help!
