42lg3000-za No Picture but got sound
    Re: 42lg3000-za No Picture but got sound
    Originally posted by dick_barton View Post
    Can you give the name and voltages on the two connectors shown.
    Photo courtesy of Shopjimmy
    where is the true way to take the volts? i measure from the red place only the negative to the other . if i pul out the white cable i make measured the red place and take zero volt..if i pull in the white cable i take 24 volt and five volt to the red place. now to take measure only the white place i have only the five volt not the 16 volt...if you wait i can sent a foto
      no i have not 16,3 volt and i have not 12 volt i have only five volt. to the white place of the volt who it send volt to the video card. what i have to look to the power suply?
        Please give the name written alongside the pin and the voltage you read
        White connector
        Pin1----> Pin 12
        Red connector
        Pin1----> Pin 12
          ok
            Can you give the pin names because I cannot read all of them from the photo and they are needed to help you.
              i have send you three fotos .please check the fotos to be sure what i send you
              red connector is easy
              pin 1,2,3,4,5 is 24 volt pin 6,7,8,9,10 is the ground-negative pin 11 is zero volt and pin 12 is 5 volt
              now to the white connector
              here we have 24 pins from count from down to up
              pin 1,2,3,4,5,6,7,8 is 0 volt zero volt
              pin 9,10,11,12, and 18 have 5 volt
              all the other 0 volt so i dont have 16,3 volt ad 12 volt
                You have the standby voltage, 5V at Pins 9,10,11 & 12
                You have ACD Pin 18
                You are missing the ON/OFF (Pin 20) and PWR_ON (Pin 19) voltages.
                To test, disconnect your main board from the power supply.
                Connect a 1K resistor from 5V to PWR_ON
                Power on the set
                Does the 16.5V supply come on?
                Do your backlights come on?
                If they do not then power off your set and connect a second 1K resistor from 5V to ON/OFF and try again.
                  i have 16,3 volt with the two cases.... with one and with two resistors.... but the screen open again for one secont and go black screen again.. and i put all connectors again and i have normal screen for one secont i just see the logo hdmi1 and black screen but i have sound
                    What voltage do you have on Pin 17 (Error) when you run the test with the 2 resistors in place.
                    Can you post sharp pictures of your inverter boards Master and Slave
                    Worth checking the fuses out on the two boards
                    https://www.badcaps.net/forum/showpo...&postcount=117
                      i have tried to write you many times but i have internet log off broblems
                        i have change the inverters with new because i check and they was broke ..to the transistor caled nikos
                          i have to sleep and tomorow i check the pin 17 and i send you fotos with the new and old inverters
                            hello to everybody...i check again and i have new.....i have meter with my voltometer in open tv the conectors from power suply to tv tuner and i have this values..
                            ,,pin 1 is 16 volt
                            pi2 is 16 volt
                            pin3 is zero volt
                            pin 4 zero volt
                            pin 5 12 volt
                            pin6 12 volt
                            pin 7 zero volt
                            pin 8 zero volt
                            pin 9 5 volt
                            pin 10 is 5 volt
                            pin 11 is 5 volt
                            pin 12 is 5 volt
                            pin13 is zero volt
                            pin 14 is zero volt
                            pin 15 is zero volt
                            pin 16 is zero volt
                            pin 17 is zero volt
                            pin 18 is 5 volt
                            pin19 is 2,9 volt
                            pin 20 is 5 volt
                            pin 21 is o volt
                            pin22 is 3,2 volt
                            pin 23 is zero volt
                            pin 24 is zero volt
                              this foto is beter
                                This is very difficult to read because you do not say what is Pin1, Pin2 etc.
                                Post #127
                                Do you have ALL the voltages when you carried this out?
                                5V, 12V, 24V, 16.5V etc
                                  ,pin 1 is 16 volt
                                  pi2 is 16 volt
                                  pin3 is zero volt
                                  pin 4 zero volt
                                  pin 5 12 volt
                                  pin6 12 volt
                                  pin 7 zero volt
                                  pin 8 zero volt
                                  pin 9 5 volt
                                  pin 10 is 5 volt
                                  pin 11 is 5 volt
                                  pin 12 is 5 volt
                                  pin13 is zero volt
                                  pin 14 is zero volt
                                  pin 15 is zero volt
                                  pin 16 is zero volt
                                  pin 17 is zero volt
                                  pin 18 is 5 volt
                                  pin19 is 2,9 volt
                                  pin 20 is 5 volt
                                  pin 21 is o volt
                                  pin22 is 3,2 volt
                                  pin 23 is zero volt
                                  pin 24 is zero volt
                                  for the white conector
                                    the white conector
                                      You do not say if you still have 24V but it looks as though you have all the voltages.
                                      If that is the case then I believe the fault must be with one of the inverter boards (Master/Slave) or with one of the CCFL tubes.
                                        i have 24 volt for the inverters...how to check again if the new inverters from china is ok ? i have check all the capasitors all the tranzistors with product name ( nikos) i check the fuse...the ccfl lamps need 1000 volt dc? i have a new tester for led tv...the output volt is 110 and 220 and 240 volt dc...can i use it to check the lamps?
                                          Firing Volateg for the CCFL can be as high as 2000VAC!
                                          We need to see the whole back side of your TV so we can see all the boards.
                                          So far you did not show us the pictures of your inverter board/s.
                                          Do you get BL-ON (INVR-ON, ON/OFF) control signal at the inverter?
