Re: powered sub wont come out of standby
Since now you have relay removed, now check to see if you have DCV on the speaker leads against circuit GND.
BTW, Q17 is the relay driver transistor, D15 is the snubber diode for the relay coil.
Also check the resistance between the middle pad where the middle relay's pin was against GND to see if it shows <1 Ohms for me.
