LG 42LH30 with no picture, audio and backlight/screen work
    Re: LG 42LH30 with no picture, audio and backlight/screen work
    Hi I am new, I had similar problem on my LG. I have replaced T-Con board, I have now half picture OK and half black screen on the left. However after keeping TV on for about 20-25 minutes whole screen returns to normal and I can enjoy TV. Wondering what the cause will be now?
      I'm new as well. Same TV, similar problem: I have an LG 42LH30 with bad color resolution. Colors are all over the place and don't respond to tint adjustments. Otherwise, it turns on just fine and the sound is also okay. I have had no trouble at all with this TV since we purchased it in Sept. '09. I've removed the back to look for bulged capacitors or other signs of loose or bad connections, etc. I can't pinpoint anything.
      My question: Is this TV repairable at all, either by me or a knowledgable technician? Or is it worm-food? Be realistic in your responses, please. Thank you very much.
        Originally posted by Nimravak View Post
        Got the SMT fuse in the mail today and soldered it to the board, replacing the old one. Ended up with the same washed out area as before. Thinking now that it is the panel itself. Kinda iffy about buying a new t-con board if it is the panel.
        Vince, I did make sure that the blade fuse was not touching anything else. It was completely free except at the solder points. Selldoor, didn't notice anything in that area of high real estate that had a problem, though I don't know what and how to test.
        So did you replace the tcon? If so results...
          Got an LG 42LH30; a lightening dropped in and tv went off. Turn it on again and now I have a blue screen, but no picture. Sound and changing channels work. I wonder if the lightening messed up the main board. Power supply seems to work okay since every thing is working except for the picture. Help please.
            Check TCON fuse
              Hi, I have the same problem, i fix the fuse and turn on mi tv appears white bars in the tv.
                What do you get on the screen if you have the ribbon cable between the T-CON board and the LCD panel connected one at a time?
                  black screen
                    black screen
                    That does not sound right, you should see white screen on the unconnected cable between the T-CON and LCD panel.
                    See post #10
                    https://www.badcaps.net/forum/showth...ight=lg+47lh55
                      My t-con board is different, use one ribbon to Main board to T-con
                        Again, may be you do not understand what I am telling you what to do, we are talking about the ribbon cables BETWEEN THE LCD panel and the T-CON board, NOT the cable between the main board and the T-CON board.
                        You have TWO cables between the T-CON board and the LCD PANEL! It does not matter if you have one or two cables between the T-CON and the main board.
                        So did you do one cable at at time?
                          https://www.badcaps.net/forum/attach...0&d=1474415342
                          That is bad panel.
