hi
i have had this f2105 for a while and when i got it i searched google and everyone said the ccfl's were bad. and at that times i didn't wont to put $60.00 into it, a while back bought a strip of water proof flexible smd 5050 leds. so last night i took the screen apart and the strip of leds fit right in the ccfl tray, this morning i put it back together for testing and hooked the two led strings to a computer psu, after testing i find the the psu on the monitor is putting out 18.98v and 3.3v and i need 12v @ .75 amp
do you think a voltage regulator will work? i was thinking of using a TO-220 L7812CV will it have to be heat sinked ?
psu for monitor is a 4h.l1s02.a20 but i can't find a pdf on it.
where can i pull the voltage for the regulator i was thinking right off the plug for the ccfl inverter being it is a spare part right now.
