HP no backlight
    Re: HP no backlight
    Thanks budm with black prob on GRN screw the read as follows pin 1- 0L pin 2- 0L pin 3- Grn 0
    pin 4- 0L pin 5 0L pin 6- 93.0 ohms pin 7-119 ohms pin 8 .780 mohms
    Jetadm123 R105 22ohms C102 reads 16.30 mohms one way 0L the other Un plugged no power
    Plugged in power on connected to running computer R102 reads 5 v one side 3.2 v other side and C102 reads .9volts one side and 0 other side and across C102 is .9 volts
      Re: HP no backlight
      Can you read C102 again. It's "+" leg is sharing VDD and should also read 3.2V.
        Re: HP no backlight
        OK, is pin 8 = 0.780 Ohm or 780 Ohms? if it is 0.780 Ohms, then there is short circuit around pin 8.
        VDD pin also seems low at less than 100 Ohms.
          Re: HP no backlight
          pin 8 is reading 0.780 megohms
            Re: HP no backlight
            If you're still seeing .9V across C102, it sounds like it's shorted to ground. I would try changing it to see what happens.
              Re: HP no backlight
              The voltage across C102 is 3.91v Grn to + 3.91 and Grn to - 0 v I have no idea where the first reading came from I thought I may have read C105 but there is 2.5 v across that one. sorry
                Re: HP no backlight
                Here are my thoughts so far:
                I looked at the datasheet for the OZ9938 and the min VDD is 4.5V. If the OZ9930 is similar, then your VDD is too low. I'm wondering if that .6V difference is enough to cause it not to operate?
                When you said you changed all the caps, do you also change C102? If not, try changing it and see what happens.
                C102 appears to be a filter cap to protect VDD against voltage spikes/noise. If you don't have a spare cap for C102, for testing purposes, leave C102 off the board and see if VDD increases. If not, then something could be wrong with the OZ9930.
                  Re: HP no backlight
                  Thanks jetadm123 yes I did replace C102. I could remove it?? I am getting slight a humming on the board as I indicated earlier and I can't tell where it is coming from but it is close to one of the transformer. T101 or T102. What does that indicate? Should that be a concern?
                    Re: HP no backlight
                    As retiredcaps mentioned earlier, the lack of VDD reading around 5V could indicate a possible short. When you soldered in the new caps in the inverter section, did you make sure that there were no solder bridges that might cause a short?
                    Also, if you continue going through the flowchart, you'll see that very few of your voltage readings meet the suggested values for I101. It's understood that since you don't have a scope, you cannot perform some of the steps.
                      Re: HP no backlight
                      I would suggest you to recheck all your works just to be sure.
                        Re: HP no backlight
                        Thanks guys I will go over the board again to be sure there are no shorts caused by my soldering. I will report back
                          Re: HP no backlight
                          I have carefully looked over the board and I am unable to see any thing that looks like a grn? I did discover a lifted trace on C122 but it is still contacting. Not sure where I go from here?
                            Re: HP no backlight
                            A lifted pad/trace on a circuit board is considered unreliable and should be repaired using point to point wiring. Solder one end of a wire to the lifted lead of C122 and the other end to solder a pad at the other end of that trace.
                              Re: HP no backlight
                              Thanks jetadm123 it appears from the schematic that the plus side of C122 (which was lifted) goes to pin 8 of Q104 so should I connect these two points?
                                Re: HP no backlight
                                Actually, connections are shown using a red dot. Therefore, the "+" side of C122 is connected to pin 3 of Q104.
                                  Re: HP no backlight
                                  Thanks jetadm123 made the connection + side of C122 to pin 3 Q104 no difference?
                                    Re: HP no backlight
                                    Well, I'm stumped. I can't think of anything else.
                                      Re: HP no backlight
                                      Ya I know what you mean Thanks pal appreciate the support from yourself, budm, retiredcaps and others on this great site. I did keep a file on the test conducted and may revisit it sometime down the road. In the meantime I have several of these that I will revisit, some with the same symptoms.
                                        Re: HP no backlight
                                        Any way, this is the resistance reading of the OZ9930 with the help of lestr:
                                        https://www.badcaps.net/forum/showth...771#post280771
                                        So I am not sure which reading is correct, yours or lestr.
                                          Re: HP no backlight
                                          @davg. If you are game, I circled a number of diodes in yellow and transistors in red. See if any of them are shorted.
                                          It should take you about 10 minutes to test them all.
                                          --- begin sig file ---
                                          --- end sig file ---
