Looking for MOTHERBOARD MANUAL MS5191
    Any one have this old manual ,cannot find it on the msi site..
    This is a fully working mobo and has a bloated cap ...just need manual to look at jumper settings and what not.
    Cheers.
    Re: Looking for MOTHERBOARD MANUAL MS5191
    How about here: http://www.motherboards.org/mobot/manuals/MSI/MS-5191/
      Thanks for the link..for some reason i went to this site but obviously i did not look hard enough lol.
      Thank you
        Can anyone tell me what are the right settings to try this 0ld mobo (it's just for practicing on ) but not sure what the settings on the SW1 should be and the jv1 setting..the cpu is a AMD-K6-2/500 AFX
        Just need to check all settings before powering on ,so if some one can give me an insight it would be appreciated.The manual can be found on the above link but i am struggling to add it as an attachment as i am running ubuntu and and just getting my head around using this
        Thanks in advance p.s not sure what the right settings i should use from the above manual.
          here is a link to the old cpu
          http://www.oldcpu.cz/CPU/AMD/K6-2/AMD-K6-2-500-AFX
            According to the manual:
            SW1 is used to adjust CPU clock frequency
            K6-2/500 should be 100mhz Front Side Bus, with 5 multiplier, so for SW1:
            4, 5 & 6 should be all set to Off, for 100mhz
            1, 2 & 3 to Off, On, On for 5 multiplier
            JV1 is the important one, controlling Vcore to the chip - not automatic with this generation, so a mistake could be fatal to the chip
            A K6-2/500 is probably 2.2v - necessary Vcore will be marked on the processor's metal cover
            Assuming it is 2.2v, you want a jumper only on position 2 of JV1
            Triple check this advice, the manual, and your settings of JV1 - no responsibility if you fry your chip !
              Thanks for that got it working
