Problems with Samsung 740N monitors
    Re: Problems with Samsung 740N monitors
    Guess its 7.5 V either single with two pads connected to one end, or two in parallel. Should not matter anyway.
      Can we see the straight shot pictures of the top and the bottom side of the board?
        I've lifted a number of the large resistors to check them out of circuit, and most of the transistors/large mosfets, they all appear to be OK.
        Pictures attached
        Edit: I borrowed some cheap calipers, the chip is approx 2.9mm wide at it's longest point, so I suspect this is a SOT23 package.
          In the meantime I've ordered two IRF7319PBF and a BZX84C7V5LT1G. I'm fairly sure those are suitable replacement parts, I'll find out next week!
            It looks like R217 is connected in parallel (need verification) with ZD201. Did you test the ZD201 off the board?
            The Cathode (PIN 3) of ZD201 is connected directly to the B+ for running the inverter circuit.
              I didn't test it off the board, but I did compare readings with a working, identical board and the two were wildly different, I guess that's not a great way to test it. I'll remove it and test regardless at some point tomorrow.
              Thanks!
                The reading error may be due to the bad 8-PIN SMD Power MOSFETs.
                  A very valid point, that did cross my mind. I could always change the mosfets first before the zener and test
                    Well, that was a little more difficult to remove than I had hoped, she was glued and didn't want play.
                    I've tested it off the board with my DMM
                    Code:
                    [ZD201]
                    0.7   OL
                    One leg doesn't appear to work at all, which according to the datasheet I think is correct (at least it is with the replacement ordered). So I assume this was working fine.
                    I'll replace it with the new one as the old one looks a little worse for being pulled out with my ham fists
                      Yeah they usually glue them to hold in place during wave soldering.
                      Nice work with the magnifying glass BTW, I am surprised you managed to focus it
                        I used a dirt cheap plastic jewelers loupe and my camera phone for the picture, they come out surprisingly well
                          That was a little harder than I imagined, but the MOSFETs are in place, the new zener and a fresh fuse. The heat sink on the back of the MOSFETs common ground makes soldering a pain in the butt, removal before hand might have been easier.
                          I destroyed one pad while removing one of them, but managed to bend the leg a little and scrape some trace so it could take a tiny bit of solder make the connection.
                          I won't post a picture of the work, I'm too embarrassed
                          It fired up first time, back lights working, etc, so I'm leaving it on the bench to see if it pops a fuse again.
                            So far, so good. I left it turned on all day yesterday and last night and she's still running. Thanks to everyone who contributed in this thread, past and present
                              Did you changed the 2 mosfets too ?
                                In all, I changed 3 of the large capacitors, 1 pico fuse, 2 x MOSFETs (replaced with IRF7319PBF) and a zener diode (BZX84C7V5LT1G) although I didn't need to change the Zener, I just destroyed when removing it to test.
                                It's still working fine today, i turned it off over night to cool then powered it back up this morning.
                                  Was it hard to solder the new mosfets ?
                                  I have had 2 ,Samsung 940T and on the 1st one (im using now) i changed 3 caps and one pico fuse
                                  and at the other one i have changed 3 caps and the pico fuse and i am waiting for the mosfets to get delivered so i can change them too
                                    How easy it is will depend on your own experience and the tools you have. Removing them was probably harder than replacing them, the glue holding them in place didn't want to let go. The heat sink also made it harder work than it needed to be, removal of that before hand might have made it easier.
                                    I used a little solder wick to clean the pads up before placing the new ones on the board, they aren't perfectly straight, but they are all working. I do have a cheap hot air station, it's quality is questionable so I managed without it!
                                      Yes i know, can you put up a pic ?
                                        The monitor is reassembled now being tested, so I can't take a picture, sorry.
                                          After changing both mosfets the monitor turned on and worked right for about 10 mins then it the back light turned off again
                                          What could it be ?
