sharp aquos LC-80LE632U led tv lamp error
    Re: sharp aquos LC-80LE632U led tv lamp error
    Your TV is a completely different ballgame the 80 inch uses LEDs that are backlit your TV uses edge lit so if you have one LED go out in your string you're going to have an array of LEDs in that same area go out causing a black patch.
      Hi and thanks that testing of codes on power-up got my tv on with leds lasting only 2 sec as usual but the rest works got sound and picture just no backlight and a constant inverted v light thanks aggain
        Originally posted by freakaftr8 View Post
        The mainboard must generate only one signal the power supply gives it if backlight is in error. All other errors are generated from mainboard. Off the error pin if it goes high it generates a power supply fault codetwo quick flashes 5 slow flashes. The error pin stays low all tje time. Without or with the backlights working I believe the mainboard monitors this by the balancing of the data and clock signals generated by the backlight driver. The pins are called adl and acl
        I have sharp LC-80LE632U tv I have no picture at all. was watching and the screen went blank. I tried a factory reset and flash light to see if the screen was on but it wasn't. I not sure if the back light is bad. The service manuel they show the componet positions and interconnections. The light is white and steady flashing when you turn the power on with the remote it goes out like power came on but the screen is still blank. Is there anything else I can do before I open this beast up. I would much appreciate any type of input.
        Thank You.
          Dont know where to start tv won't power up at all. Tried reset with the input and volume down holding and pluged tv back in. No luck, anyone know anything about where to start to test to find the problem. I hate to open this beast up unless I really have to. The power light is white and flashing steady. When you power up on the remote it stays on steady. The screen is still blank, anyone have any idea's. The service manuel doen't tell you anything it just tells you how to take it apart and the layout of all the boards that interface with each other.
            freakaftr8, I don't think you posted how you repaired your TV in the end?
              Please help!!
                Im hoping I can fix this, if anyone can help
                  Hello Sacosta
                  This is a different model so you would be better off starting a new thread.
                    yeah, I apologize. I had verified my email and all but still wouldn't let me start a new thread till today. Thank You!
                      Please help!!
                      Have you hooked up different inputs and it happens on any of those inputs?
                      Permanently Retired Systems:
                      Kooky and Kool Systems
                      sigpic
                        service manual shows input vol- at the same time in plug in TV but when I try to do that I get the one flash two flash sequence I can't get it into service mode. the only way to get this set to turn on is to hold down the volume down channel up button at the same time but that wont allow going to the service menu
                        What was the fix for this? I am having this exact issue and the fix was never posted. I am having these EXACT same issues with a Sharp LC-70LE374U. If I hold the vol+ and channel- when I start the tv, the tv works great.
