One more. . . I Bought This Kit but I Can't Find Where Some Of These Are On The Board. Are They All Necessary To Change? (sorry For The Weird Keyboard Capitals :$)
Just Realized The Smaller Pieces Are Packaged Together. . D'oh
There's heaps left there to solder onto. Just clean off the burnt solder\soldermask around the hole, and scrape some of the good soldermask back to expose more copper.
-David VanHorn
You don't generally need to replace the entire kit, however there are 2 reasons you should absolutely replace the entire kit.
1) The kit provides you with parts that commonly fail. If you only replace some of them, the others will fail soon. The IGBT's and resistors go out due to the cracked solder joints on the inductors, however the 8 pin ic's can go out on there own without any other problems on the board. So why not change them if you can.
2) trouble shooting all the parts to know if they are good or not will take you longer than just replacing them, so why not just replace them all.
Lastly, if some of the board is burnt and you are not able to find exposed copper, you can go ahead and scratch the board to expose more copper, however you will want to be careful when doing this as I have seen to many people scratch way to much and rip off the copper they were scratching for.
Also just a heads up but the belly of those 8 legged IC's are glued to the board.
The reflow of the coils looks fine, however between the legs of the top middle coil and the top left coil there is a small blue capacitors leg that has a crack. reflow that as well. It shares the same pad as those coils so it gets overheated as well.
