Gateway FPD2485W won't turn on
    Greetings,
    I have a Gateway FPD2485W that does not power on. when plugged in, the power light doesn't even glow, it is simply dead. I've replaced all the caps on the power supply and the 2 on the inverter board, but this hasn't made any difference. Does anybody have any ideas? I'm sort of a novice when it comes to component level repair, so any suggestions would be great!
    Re: Gateway FPD2485W won't turn on
    First, are you sure you have the flat flexible cable installed correctly from the logic board to the front panel switch?
      The standard procedure here is to post clear focused pictures of all your boards (top down view) using the manage attachments functions so the pictures are attached to this forum. Please do not post inline because it slows down the loading of pages.
      After you have posted the pictures using manage attachments, we can suggest test points.
      --- begin sig file ---
      --- end sig file ---
