When replacing fuses in monitor power supplies, should you use the slow-blow kind or the normal kind?
fuse question
Re: fuse question
Originally posted by Undead View PostWhen replacing fuses in monitor power supplies, should you use the slow-blow kind or the normal kind?
If its SMD then most of the time i see them as fast blow. If its the main fuse right after the power input then most of those are slow-blow. It just depends on the application.
Re: fuse question
It often tells you on the board - there is a message saying use ONLY the same type of fuse?Please upload pictures using attachment function when ask for help on the repair
Re: fuse question
If you look on the metal shoulders on the fuse it might say more.
What I am thinking is that if it is a slow blow it is usually described as a T4A 250v T= Time delay. Otherwise its a normal fuse - you should replace glass with glass ceramic with ceramic. (Not that I always do)Please upload pictures using attachment function when ask for help on the repair
Re: fuse question
If you are working on a board that repeatedly blow fuses put a filament light bulb
across where the fuse would go. If this is a mains fuse use a 40 or 60 watt 240v bulb.
If there is a short the bulb will light bright if not it will light then dim as the board powers up saving fuses.Please upload pictures using attachment function when ask for help on the repair
Re: fuse question
Well I'm hoping that it won't repeatedly blow. I just got the monitor (was turned in for recycling) and after replacing the caps since there were bad ones, it was still dead. I checked the fuse and it was bad so I figure it won't hurt to get a few extras "just in case" since I have to place an order anyway.
Re: fuse question
Originally posted by selldoor View PostIf you are working on a board that repeatedly blow fuses put a filament light bulb
Re: fuse question
aqibi2000 - here is a link with more info.
8Amps is quite hefty what are you working on? - Perhaps you need to start a thread? and ask for help.
http://www.ea8ay.com/fairbanks_morse...ts/dimbulb.htmPlease upload pictures using attachment function when ask for help on the repair
