I am a big noob but eager to learn so.. please help me to understand how DC electricity in laptop motherboard works and all through the nets... so, there are many nets on the motherboard...for example basic are gnd-ground, nv-negative, pv-positive....
And, off course when i plug the charger in, the DC electricity is going from positive part in charger to all chips and other parts in motherboard, powering them up, and coming back to charger through negative and ground? making the whole circle? off course, on its way mosfets, diods, resistors... are changing voltage, resistence to supply each chip, card, memory modul, cpu with voltage needed to work. Is this correct?
Further, when charger is not plugged there is no connectivity or should i say continuity in the whole motherboard, because there is no closed circle. But, if i use multimeter i will see that lets say ground and negative are connected, and they shouldnt be in any way connected to any other net? positive or other? cause that would mean that there is short somewhere? further, should all other nets have no continuity also? lets say net +5vs and +5v_kbled? should they have continuity if charger not plugged?
Please answers/advices, links to books/pdf on the theme very appriciated
