Recommendation for a Power Supply for Testing
    Can anyone recommend a variable power supply for testing. Something simple.
    Re: Recommendation for a Power Supply for Testing
    First, what are your requirements (or primary uses) for such a unit?
      Hi Japlytic,
      Well, to be honest I removed the car stereo from my vehicle because I am not getting any sound out of the Left Front Driver side speaker. I would like to be able to run the car stereo out of the vehicle and test the outputs but need a way to power it.
      Unfortunately I have a bigger problem as I cannot find a wiring diagram for this unit so not even sure where to connect the power for the 12v DC.
      I think I could just use a 12v battery, but again how would you figure out which pin to put the power to?
        Any old PC PSU is capable to handle the load of 3-4A that you will have by setting the volume high.
        About the wiring issue this is your business.
        Possibly it would help to open it up and find the cables from inside, the Red one.
          Usually going to the radio manufacturer webpage and getting an installation manual will do the trick on how to power the radio up.
          A Picture of subject is always Welcome
          Things saved from the e-landfill:
          Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
          Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
          MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
          ViewSonic VA712B - still working on it
          Kindle Fire USB Connector
          MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
          MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
          The list will go on thanks to the people of this forum and many hours of reading.
            I had purchase an power supply DPS-712M from Zurich brand for about 60$ to an electronic store. It's variable and it support max to 6A.
            I use that for car radio, led projects, and its give you the AMPERS that it used for your project. A great investment.
            Great for any 12V project. You can go up to 20V!
            That's the one i had.
            http://www.mgelectro.com/fr/bloc-dal.../dps-712m.aspx
            Here in montreal in Canada, i found it at 59.99$ canadian. Check on local electronics store supply.
              well, not to be an ass, but generally speaking, for us here on badcaps, it is more fun to make adjustable ATX mod, instead of buying another one.
              have recently finished one.
                Yeah i understand, but for who doesnt had the experience like me, its another solution.
