Dell Inspiron 15R-5537 Bios Password
    hi
    is there a way to reset the bios password of dell inspiron 15r-5537
    its service tag is new one and doesnot end with -595b or others
    thanks
    Re: dell inspiron 15r-5537
    try this bios
      hi try this bios
        I forgot the password for Dell Inspiron 15R-5537 Laptop. It's Service Tag is : 4G5RQY1. Anyone can give the master password for this.
          Re: Dell Inspiron 15R-5537 Bios Password
          Try these 6020005,70obi6r9,d5gdrcut,7zp4GKrG9syFZN7w.
            It shows System disabled " BFD405093B291DF0 " and service tag " 4G5RQY1 " after i put your codes
              hi try this bios
                I flashed the bios with the new dump. but still it ask the password.
                  try this, working dump
                    Thanks for your file. But after i flashed with your file, Laptop not starting and it switch off again after 2 seconds.
                      Need Dell 15R 5537 EC+Main Bios. Its having password on io controller
                        when you flashing with niggi file, is ppid and servicetag still same displaying with your original ppid/servicetag? if that happen, yes your password is stored at kb9012 ... i try to trace for niggi file, cannot found servicetag/ppid...
                        this is kb9012 files maybe fit for your board...
                        you can compare with your backup original kb9012, before flash..
                        for main bios i think, you can use niggi file
                        fyi: you can get ppid and service tag this kb9012 with hexeditor at 1E000 address...
                          Thanks RIORENO. My programmer ( TL866CS ) doesn't support to do KB9012. I just ordered for RT809F Programmer, and it will reach me within 15 days. I will get back to you soon.
                            Hello RIORENO
                            can you show me how to retrieve password from dump of super IO KB9012. I want to
                            dump flash from IO with CH341 programmer. It seems that activate EDI on this superIO can access directly embedded SPI.
                              I done this password clearing with RT809f programmer successfully. Thanks for all support in this thread
                                Hello there,
                                I'm trying to repair a Dell laptop with a Bios Issue.
                                I downloaded the file you have post on May 2016 and flash the bios chip with my external programmer (TL866CS)
                                Unfortunately it didn't solved my problem.
                                I'm convinced that the bios is corrupted,the Laptop is turn on and the fan is spinnig, the screen is BLACK and I hear 2 beeps one is loud and the next is low.(repeatedly).
                                The model is DELL 15R-5537
                                MotherBoard model VBW01 LA-9982P, REV 3.0(A02)
                                Do you have another bios file that you took out from a working motherboard?
                                Or do you have any ideas for my symptom?.
                                Thank you very much for your time and help
                                  Thanx a lot!
                                    I am having the same password problem on bios. But I do not have the bios burner .... I would like to edit the Bin file and flash it through Insydeflash.
                                    If anyone already has the file and share thank you.
                                    Hug to everyone.
                                        need password Inspiron 15R 5537
                                        hello
                                        please need password dell Inspiron 15R 5537
                                        System disable : 2DE90579CE1B2571
                                        Service tag : 6113502
                                        thank you
