hey guys, this is my first post in this forum so i hope im doing everything right
so i hava a Samsung Syncmaster 740n that stopped working properly (blue led was on but no picture)
i did a little reserch and found out that the three 820mf 25v capacitors on the power board were bad, it took a while but i eventualy found a store that sells 820mf 25v caps, i bought them and replaced the caps.
when i tested it out (before reassembling the plastic casing) i could see that the lcd was working, however the backlight was not.
what do think the problem is? and how can i fix it?
- when i reassembeled the screen to the board i accidentaly connected bouth of the pink/white cables to the place where the black/green should be (see image - http://img683.*************/img683/4687/asdfkk.jpg ), and turned it on for like 4 seconds, could it burn out the backlight bulb?
