um...dishwasher?
    Re: um...dishwasher?
    Keep in mind bad/cracked solder joints on circcuit boards where harness plugs into.
    2 years ago I think, I helped my friend fix his recent front loading cloth washer.
    The controller board/box is above the drum tank, friend knew about electronics and repair but was not sure if it was joints. So I took good look and they were.
    No problem since.
    Cheers, Wizard
      Um ....well i worried away on the Fatal1ty into the night and wee smalls
      New PSU altbough the original tested fine without load..AND... mucho patience clearing and resetting the CMOS
      Anyways here it is chugging away nicely
      939 DualCore AMD Opteron, 1800 MHz (9 x 200)
      Abit AN8 / Fatal1ty AN8 SLI Series
      3072 MB (PC3200 DDR SDRAM)
      ATI Radeon HD 4300/4500 Series (1024 MB
      Lian LI Aluminium mesh case
        I believe you've successfully hijacked your own thread...
          I is not having much success with the dishwasher
            So where are you up to with it?
              somewhere there will be a list of blink codes for it.
              might be easier to figure out who really built it.the name brand may be more common than the rebadge and easier to get info for.
                From my searches, it seemed to be related to Electrolux.
                  http://www.ApplianceJunk.com <-- has some factory manuals
                  http://www.FixItNow.com
                    Thanks Larry still sifting through it.If there is any news about this animal on the net its damn well hidden
                    I might go hook up the pump directly to the AC and see if we got a runner there
                      Is the pump supposed to run on AC? That may be a bad idea...
                      Surely it gets DC from the circuit boards...
                        The pump is a big load.
                        Might be AC or DC - NEED TO CHECK...
                        Mann-Made Global Warming.
                        - Dr Seuss
                          Just had the manual emailed to me by a nice guy in the business
                          Has all the test programs and circuitry
                          Pushing buttons I will go!
