KDS K-92BW Turns off
    Re: KDS K-92BW Turns off
    when I test the s1 s2 s3 s4 do I put the positive on s1 and negative on s2 and same with the s3 s4 for testing or how do I do this?
      when I put the positive on s1 and negative on s2 I get 763 when i put the positive on s3 and negative on s4 i get 763 is this ok?
        should i replace the caps in the badcaps pdf picture
          Ok Inverter Transformers are good.
          Components inside the yellow boxes in my pic are Mosfets
          I attach the datasheet.
          Attached to retiredcaps post is a guide on 2 seconds to black - in there it tells you how to test Mosfets You do not need the board powered to that.
          It also mentions testing ccfl bulbs -do you have anything you can plug the lamps into to test them?
          The board does go black sometimes - it does get hot but it may be from the K3615s that was why I was asking if the lower one looked burnt.
          You can replace the caps - I was only getting you to test
          other components first to save money as for a 19 in screen it is relatively expensive to replace the inverter transformers or the bulbs
