Dell 2007wfpb power on problem
    Re: Dell 2007wfpb power on problem
    When i tested the connector i put the black probe to the ground on the power board and also tested from the black connector wire. So i had the Power board and the Inverter board on my desk plugged in to the wall. (Maybe slightly dangerous )
    Ive attached better photos of the power board.
      I think Smason wanted the MAIN board ie the other one that we have no pics of.
      As you have posted these there are a few soldering joints I would like you to
      check and possible resolder. In addition to the one in the picture there is
      D701 in another pic.
      EDIT also reflow all the jopints on the transformer T601 which straddles the black line.
        Ok here is the pictures of the other 2 boards in the case. I assume you mean the square one but i included the USB board just for reference. Re-soldering the ones you pointed out as we speak,
          Hmm Usb board - there are some monitors that will not work properly when this is not connected during testing but dont know if this is one of them. On that board there is a fuse -please check it and post result.
          in pic 5 there are two voltage regulators in the bottom left corner One is a 952T43
          - cant read the other one - at U5.
          Please read this
          https://www.badcaps.net/forum/showthread.php?p=261329 by retiredcaps on how to identify, test and post the results.
            Please see this:
            https://www.badcaps.net/forum/showth...007#post289258
              Ohh! Awesome post, somehow I missed that one in my search.
              Explains a lot.
                ok i plugged everything together and re checked a few things.
                the fuse (white thing close to board connector) is 18.9v on both sides . the connector on the power board now reads 18.9 volts on all the wires except brown
                the missing voltage regulator number is 950T65
                as per https://www.badcaps.net/forum/attach...7&d=1336881135 they both have the correct voltage.
                Thanks for the referral to the other post!
                  also a quick FYI i plugged the screen in and tried to power it on again after re soldering and the various tests and still the same thing flashing led
                    Error - sorry
