Samsung 244T
    Samsung 244T
    Can someone help me with a Samsung 244T service manual please
    Doesn't switch on (yes its power switch at the back is On)
    Need to get started with removing its cover, and don't want to just attack it with a screwdriver in case there are pitfalls
    Google seems to return a mixture of user manuals, dodgy sites, and places that want you to pay
    Re: Samsung 244T
    Anyone ?
      Re: Samsung 244T
      Here is how I take it apart:
      http://s807.photobucket.com/albums/y...AMSUNG%20244T/
      You lift up the bezel then work you way around using flat wooden (Popsicle stick works well or plastic stick. Just do not completely lift the bezel off since there is small cable attached to the switch assembly, just lay it face down then lift the back off.
        Re: Samsung 244T
        Thanks budm, just what the doctor ordered
          Re: Samsung 244T
          I have the same problem. The power switch at the back is on, but no light is on when try to press the power button in the front. What could be the reason?
            Re: Samsung 244T
            Open it as above posts,and submit photos,if the fault is not obvious when you look at the boards ie blown caps and fuses etc.
              Re: Samsung 244T
              Opened it with pictures at:
              https://www.badcaps.net/forum/showthread.php?t=29444
              Would you mind taking a look and advise me your opinions?
              Thanks!
                Re: Samsung 244T
                Believe it or not...
                Downloaded a copy (for free) of the Samsung Service Manual for the 244T today...
                Send an email to canadiantech8@gmail.co* and I will send the zip file.
                Regards...
