Samsung SyncMaster 216BW question
    Hi, I replaced some swollen capacitors in my samsung syncmaster 216bw monitor and it powered on but i notice when i connect it to the computer the image is all out of place so i figured i just need to push the auto button but that doesn't help. it just moves the image up 1/4 of the screen and left about 2 inches the only time i can get it to line up properly is if i go into the menu and select reset image. any ideas on how to solve this problem?
    Re: Samsung SyncMaster 216BW question
    Check, clean, reseat every internal cable whether you touched it or not.
    --- begin sig file ---
    --- end sig file ---
      hi again thanks for the reply i tried what you suggested but it didnt work. what step should i take next?
        In the menu system there should be a reset. Try it.
          I already did the reset its the only way to get the screen to center at best but it the auto button thats not working
