Hi, i have problem with 17" HP L1706, i have done recap. Monitor turn on and "check signal" logo is OK, but when i plug in the RGB cable the picture is too lighten and color are not good. I have try to factory reset, change cable, check cable between board and LCD. The problem is grey is light blue and things like that. I use exact value when recaping.
Hp l1706
Re: Hp l1706
Does it have the same problem if uses with another PC?Never stop learning
