Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 03-05-2015, 09:41 PM   #1
njgretz
City & State: Lith Illinois
My Country: US
I'm a: Knowledge Seeker
Default Need Help Phillips 47pfl5704d/f7 Screen just died
Please take a look at the pictures, have you ever seen this before?
Watching TV with my wife and boom, this happened.
No impact just watching TV.
As you can see after 2 minutes the whole thing brightens up.
I replaced the T-con board just to rule it out but didn't change anything.
It looks like all of the gate drivers are permanently connected to the screen.
Any ideas other than replacing the entire screen?
njgretz is offline   Reply With Quote
Old 03-05-2015, 10:37 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Need Help Phillips 47pfl5704d/f7 Screen just died
Bad screen, I have seen it before, nothing you can do except replacing the LCD panel.
__________________
budm is offline   Reply With Quote
Old 03-07-2015, 10:47 AM   #3
njgretz
My Country: US
Thanks for the confirmation Budm.
Have you ever tried using the heat/air gun on a rework station to re-heat(resolder) the connection to the LCD? I'm thinking about giving it a try. Can't hurt at this point I guess!
Old 08-12-2017, 12:35 PM   #4
Shadetree83
City & State: Columbus Ohio
My Country: USA
Has anyone found a fix to this issue? Or is a new panel still the only solution? Is there anything that can be done to repair a panel like this one? And just for information sake, what actually is the problem here?
Shadetree83 is offline   Reply With Quote
Old 08-12-2017, 03:29 PM   #5
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
If you have or know someone with a tab bond machine. You can repair them.
__________________
dskall is online now   Reply With Quote
Old 08-12-2017, 08:01 PM   #6
Shadetree83
My Country: USA
Thanks for the reply. Just so you know,I am a novice at the art of electronics repair. However unlike an old dog, I can be taught new tricks. Could you walk me through this processs or send a link showing how its done? I can usually repeat a process if I have seen it done or have been explained how to do it.
If the panel is actually toast, then I really have nothing to lose. But if there is a chance to save it I would really like to try.
Also, if its relevant, could you go into a little more detail of the problem of the display
Old 08-12-2017, 08:22 PM   #7
dskall
dskall's Avatar
My Country: usa
the process: https://www.youtube.com/watch?v=QMAeQZBfbls
Old 08-12-2017, 09:48 PM   #8
Shadetree83
My Country: USA
Ok, so I watched that video and a few others and I have a few concerns.
1) Nobody in these videos look like they are doing this at home. I see a lot of technicians and laboratories.
2) there seem to be some supplies and chemicals involved ( which I cannot identify since these videos are in a different language)
Is this something that can be done at home or am I just wasting time
Old 08-12-2017, 11:19 PM   #9
dskall
dskall's Avatar
My Country: usa
For all practical purposes the defect is like a cracked screen. nonrepairable unless you want to spend thousands of dollars
Old 08-13-2017, 02:17 AM   #10
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
They use 3M Anisotropic Conductive Film and the chemical they use for cleaning is probably isopropanol.
It has to be aligned perfectly and then applied with heat and pressure.
There are a couple of threads on here with members talking about DIY methods.
The tape is over $200, needs to be stored correctly and has a shelf life.
diif is offline   Reply With Quote
Old 08-13-2017, 06:10 AM   #11
Shadetree83
My Country: USA
Well sounds like I will have to do some more searching for some band-aid type fixes to see if I can get it playing again. I'll also look around for some shops that might have this technology an see what their charging.
Wish you had some better news for me. I was really hoping there was a way to fix this at home. But if i can't I will have to look for a new panel or I might just be parting it out.
I appreciate the info received and will definitely be back for more.
Old 08-13-2017, 08:44 AM   #12
Moreno83
City & State: Overijssel
My Country: The Netherlands
Line Voltage: 230V
It is extremely hard to repair a panel yourself. It is fun if you have the money to spend on material and machines so you can fix many tv's .....but just for this tv only its not worth it.
Temporary fix is to apply pressure on the tabs. This is a common philips LCD fault.
Moreno83 is offline   Reply With Quote
Old 08-13-2017, 08:05 PM   #13
Shadetree83
My Country: USA
Yes, that's what I see thinking. I saw some " fixes" using pieces of plastic and other rigid materials. Have also heard of surgical tubing. Though I was thinking of finding something a little more stiff, but not as stiff as plastic or wood. Any suggestions?
Really wanted to get this going before the Buckeyes started but I'm running out of time. O-H!
Worst case scenario I'll end up having to get a new or refurbished panel but I'm having trouble there too. Anyone have a lead on a LC470wuf-sba1 ?
Old 08-14-2017, 04:03 AM   #14
Moreno83
Line Voltage: 230V
Buying a new lcd screen is not an option , it costs more then a a brand new tv! Also with these company's you need to buy like 100+.
And why spent so much money on a 3/4 year old tv.....
You need to use something that is heat resistant , the COF ( chip on film ) chips get really hot.
Squeeze the bezel when the fault is occurring , it will probably get better of even disappear.
Old 08-14-2017, 09:26 AM   #15
dskall
dskall's Avatar
My Country: usa
You can try some thermal pad. That will apply pressure and dissipate heat
Old 08-14-2017, 08:59 PM   #16
Shadetree83
My Country: USA
So here's another point. All of the similar issues I have seen like this, with the fix we are talking about, all had vertical lines running from all the way from the top to the bottom of the screen. Why on my tv,like the pics above, do I have one good strip of picture that runs across the top. Is my picture running horizontally? I haven't torn the tv down to the panel yet to find, or tinker with the tabs yet. Are they ever on the side of the panel? Maybe the signal only gets that far down before the signal fades out too much to create a picture l? Then I ask, if there are multiple tabs did the board opposite the panel (between the panel and the t-con) go bad and is not sending a good signal or all the tabs failed the same way at the same time (seems unlikely).
Again, thanks everyone putting up with my questions, which might be silly to the experts here. But if you don't ask,you'll never know.
Old 08-15-2017, 12:30 AM   #17
Moreno83
Line Voltage: 230V
I get your point but im sorry , this panel is shot!
I had the 8404 model with ambilight and when it was on the screen got the same like yours. Looked like a fragment of the film "The ring" , i was waiting for the girl to get out of my tv.
Squeeze the bezel top right/top left and see if it gets better. Or hit it on top....
Old 08-15-2017, 08:03 PM   #18
Shadetree83
My Country: USA
I get your point. And I do believe its the panel. Just wondering, for informational purposes, why this model fails like this when others fail with the vertical lines.
It took me forever to even find a post like this with the same symptoms and anyone with any useful info. Probably this Fri or Sat I'll dig into it a little more. I'll be back to post my results.
Old 08-16-2017, 12:26 AM   #19
Moreno83
Line Voltage: 230V
It is not just this model. Alot of philips tv's give the same symptoms.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
