Samsung syncmaster t220 Powers on no screen.
    Re: Samsung syncmaster t220 Powers on no screen.
    Originally posted by eniac22 View Post
    I have also problem with this monitor, backlight is working for 1 sec and then black screen, i check the capacitors with a esr meter and seams to be good.
    - I've checked the voltages at the connector:
    1 -> 0.11V (BL_ADJ_PWM)
    2 -> 15.38V
    3 -> 0V (GND)
    4 -> 0V (GND)
    5 -> 5.20V (5V_IP_1)
    6 -> 5.20V (5V_IP_2)
    7 -> 0.54V (BL_ADJ_ANALOG)
    8 -> 2.56V (BL_EN)
    9 -> 3.25V
    10 -> 2.97V (LED)
    11 -> 3V (KEY1_OUT)
    12 -> 1.78V (KEY2_OUT)
    any help?
    Ok i found that 2 of 4 CCFL lambs is dead, i try lambs from other screen and is working ok
      If you look at the thread, you will see that your pins:
      What do you get on those two pins now?
