I made a PCB for my little 3842-based flyback PSU which uses a 5vsb transformer from an ATX PSU. It didn't work. The 3842 didn't output Vref, so the oscillator wouldn't start, hence no drive to the MOSFET -> no output.
I checked the PCB a dozen times and found nothing suspicious. I spent over 3 hours trying all the 3842s i had, i think i went thru 8 or 10 of them. Note to self: sockets.
Then, before going to sleep, i thought i'd look at the UC3842 datasheet another time. UVLO threshold for the UC3842 is 16v, and i had a 15v zener on the 3842's Vcc pin. Son of a... Sure enough, i disconnected the zener and the supply fired right up. Now, i don't recall why in the world did i put a 15 volt zener there, but i did. It says so on my schematic too.
So... when your circuit won't start, read the datasheet one more time. You might just catch that brain fart you had when building the thing.
