CR620 (MS-16881) turn on once for 2sec and then die
    hi guys
    i have another weird problem again
    when i plud ac,board turned on immediately,everything is true,even show display,but just for 2sec
    and then it dies
    just +3/5VALW is on
    not respond to power key
    when i press PWR_SW nothing happen on PM_PWR_BTN#
    but when i manually connect PM_PWR_BTN# to GND it turned on for secends and die again
    i program Bios&EC
    i replace KBC but no change
    there is no diffrence with or without cpu
    i hope someone help me
    tnx all
    Re: CR620 (MS-16881) turn on once for 2sec and then die
    The laptop turns off probably because a RUN voltage is not present after power-on.
    you have to check if all the powergood signals are OK after power-on.
    Specifically, pin17 of KBC.
    However, you have about 2 seconds to check these signals and voltages.
      problem was here
      PWR_SW# was 0.3V
      i replace R35
      nowPWR_SW#=3.3V and it works
      end of topic
        can you please share the block diagram and boardview for this model please
          i use MS-168A schematic
          its almost same
            thank you for sharing
              Here i found this as well
                hi all.... this post is old, but I have some weird failure with same model (MS-1681) Laptop is powering on, everything is fine... then turns off suddenly while is booting up, and after pressing power button nothing happens... I realize that testing it without HDD , booting Windows PE thru USB the laptop keeps on... even I have stressed it with CPU-z and everything is fine... when I put back HDD again goes off... (also tryed with others HDD).. question: I´m assuming the issue is on SATA controller or HDD power controller. Someone could share its experience with it ? thank you
                  i would check the hdd connector for short .
