Thread Tools | Display Modes |
#21 |
City & State: Belgrade
My Country: Serbia
Line Voltage: 230v 50hz
I'm a: Hobbyist Tech
I do have visual access, but my speakers are at my home, and I'm at work, so I'll do all that when I'm back home!
#22 |
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
I'm a: Knowledge Seeker
Ok!
__________________
Hi-pot test: FAIL |
#23 |
City & State: Near Cincinnati, OH
My Country: USA
Line Voltage: 120VAC 60Hz
Measure the voltage at the V+/V- pins and ground for the LM4558 as Ben7 suggested. If it is not so high as to damage the opamp, then replace the two large caps right after the diodes. If it is too high and damaged the opamp, replace that too.
#24 |
My Country: Serbia
Hi ben7.
OK, i plugged it in again, and watched the speaker cone. It doesn't suck in, nor does it push out. It starts vibrating immideately, first small vibrations, for a second, and then with, i guess, full power. Measured what you told me. Upper black contact measures 0.48, and lower is at zero. Multimeteris set to 20V edit: that was with the speakers turned off. When I turned them on, voltage on the upper is about 9.27 (it's variable, but around that value), and on the lower is constant -0.7. Multimeter is again, on the 20V setting. Those black circles are legs of the two caps (100 uf, 25v). I am looking for the 4558 datasheet so i'll know where are v+ and v- legs. Then i'll do the reading Last edited by bocca; 07-05-2012 at 06:02 AM.. |
#25 |
My Country: Serbia
OK, so here's the datasheet:
http://html.alldatasheet.com/html-pd.../1/LM4558.html What should I measure? And should i do it with the speakers powered on? |
#26 |
Warranty Voider
City & State: West Tennessee, USA
I see NP on the electrolytics... are those nonpolarized caps?
#27 |
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Pin 4 is B-, pin 8 is B+ on the OP-AMP. You put the black probe of the meter to the DC ground (you can use the RCA input jack outer body for ground, the red will be used fro checking the voltage with speaker on.
__________________
Never stop learning Baisc LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#28 | |
My Country: USA
Quote:
FYI: I traced the tracks, which was very easy due to the good pictures, and those are the + and - power rails for the opamp. Can you please measure the resistance of R44 (its a 470 ohm resistor)? |
#29 |
My Country: Serbia
will be done tonight people. Once again, you have big thank you for your patience!
#30 |
My Country: USA
| Thread Tools | |
| Display Modes | |
