What are you guys using for a ventilation system when you are desoldering and soldering?
Ventilation System
Re: Ventilation System
Usually just an open window a few feet from my workbench. It's the best I can do in my basement at the moment. Luckily I don't do extensive soldering, so that one window is sufficient. If I ended up soldering things more frequently, I'd set up a window fan with aluminum dryer ducting to extract the smoke and fumes. It's cheap, but it'll do the trick!
I made this from Bath room fan and Charcoal filter.
http://s807.photobucket.com/albums/y...t=DSCF0519.jpgNever stop learning
