I have an LC-B300ATX. It is based on the not very usual 2003 IC PWM controller for which I have difficulties in finding datasheet. Recently I have noticed +5VSB being too high. When the PSU is cold, +5VSB starts as high as 10V then drops slowly (within minutes) to 6,6V for keeping that value, which is not acceptable.
So far as I have seen, the schematics is similar to the 250W version found here: http://danyk.cz/s_atx04a.png.
I have some basic questions about the way +5VSB is actually generated:
1) Does the +5VSB use a standalone 2 transistors oscillator for switching voltage generation or is it derived from the PWM controller output?
2) Is there some feedback to insure voltage stays as close as possible to +5V or is it unregulated?
3) What is the optocoupler labeled "COSMO" for? Is it a feedback for regulating +5VSB by adjusting the bias current of Q4?
I've noticed C18 is getting really hot and keeping a finger at its end is barely sustainable. But it may be normal temperature as this capacitor constantly gets the pulsed voltage issued at D7's cathode? D7 is also hot. Same for the COSMO optocoupler.
May be Q3, Q4 or both transistors are damaged, but I made oscilloscope recordings of the voltage at D7's anode and I can see near square alternating waveform voltage.
So which component should I check first?
Thanks a lot,
Pierre
Thanks a lot,
Pierre
