Endless repeated beep ?
    Re: Endless repeated beep ?
    Faulty memory, no memory, beep beep beep.
      Originally posted by bianchi77 View Post
      Guys what does it mean by endless repeated beep ?
      Reseat the RAM... It's a RAM code, at least with an Award BIOS...
      CPU problem probably would be zero bleeps...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      16 GB AData XPG Spectrix D41
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        Ok, it means the CPU is doing the job...it's compatible...
        only the spec is saying it's not compatible but in the circuit it's doing the job...
        All right I'll have a look again and post...
        Cheers
          Ok...here's what I got....
          when there was no memory.....POST = C1C1 and short beep repeatedly
          and I put memory...the beep is gone but it's still POST = C1C1 and not moving anywhere...
          I try to seat memory on every position and combination...still the same...
          and the memory is fully tested working....
          So return again....does the CPU matter ?
          because I don't see something running on POST diagnostic at all only 0000 then jump to C1C1 and freeze with memory....without memory same thing with short beep repeatedly...
          Any ideas ? or clueless already ?
            Currently I'm using Celeron D 346...it's outside from the list...
            Msi MS-7352 CPU Support
            MSI MS-7352 Mainboard Processor Support List.
            * Celeron Dual-Core Processors:
            E1200, E1500
            * Celeron Processors:
            420, 430, 440, 450
            * Pentium Dual-Core Processors:
            E2140, E2160, E2200, E5200, E5300
            * Core 2 Duo Processors:
            E4400, E4500, E4600, E6320, E6420, E6550, E6850, E7300, E7400, E8600
            * Core 2 Quad Processors:
            Q6600, Q6700, Q8200, Q8300, Q8400, Q9400, Q9500, Q9650
              The BIOS belongs to HP, so may be there are some revisions, it's not either AMI or AWARD...
                it has ability for this celeron, ( celeron 420 ) :
                http://ark.intel.com/products/29734
                what I used (celeron D 346 ):
                http://ark.intel.com/products/27125/...Hz-533-MHz-FSB
                That's the CPU fact I can see...
                  There's a possibility that BIOS is scanning for CPU id and saying it's not CPU...that's what I can think of from the data I have read..
                    Seems just as likely for there to be termination voltage issues... Possibly with it appearing to be a 90 nm! Especially on-die RAM termination and/or FSB termination...
                      okay, if that's what you think, what voltage should I see for RAM ? 1.8V ? which FET ?
                        So you think the motherboard can accept this Celeron 346D ?
                          1.8 V is standard for DDR2 SDRAM voltage.
                          And for the FETs I would first check the CPU FETs then the RAM FETs.
                          It looks like it should work with a Celeron D 346, because it's socket 775, but dunno...
                            Ok, let's see the FETs voltage...what's the normal voltage for CPU ? 1.25 -1.38V ?
                              I tested on FET, which is the biggest near the CPU = 09N03LA
                              Diode test in circuit drain to source =0.23V either way .... black to red, red to black probe...normally one of them should be OL
                              And it looks burn....there is chance, this one is the faulty FET..since I can't see the label anymore...could be burned ?
                              I'm not sure, because I haven't seen the voltage on it...
                              In progress...
                                and the FET is in circuit, so it could be something else unless I desolder and check it..
                                  So you checked the memory with memtest86+ ?
                                    I've checked the memory, no problem
                                      I've measured the voltage for DDR2...all are ok 1.8V...and voltage for CPU 1.35V which is normal...
                                      The only thing I can think of, is testing it with the proper CPU according to the spec...
                                      Clock is ok I reckon...I can see 0000 jump to C1C1 and blinking LED repeatedly, and beep....at least it's responding to clock generator...
                                        u have to use one of the cpus in the supported list. there are some oem boards out there which will only work with cpus in the supported list. the cpu u are trying to use is a prescott based celeron with a 533mhz fsb. i believe the motherboard can only work with cpus with an 800-1333 mhz fsb from the cpu list u posted.
                                        also, it seems the motherboard will only support cpus based on the core architecture. cpus based on the prescott design are unsupported thus the mobo will not post and the mobo will just "play dead" instead. i've seen some mobos play dead if u try an unsupported cpu.
                                          @chaoslegionnaire....
                                          Yes, that's what I've been thinking, my mobo doesn't support prescott core,
                                          I need conroe core at least....it has the same LGA775 but different core and the BIOS is already designed to detect CPUID....and if it's not right...no POST...
                                          I'll find conroe CPU and keep posted..
