Disconnect the button board and see if it still does it.
Yes, disconnect from button board while on, and wait and watch.
Some of button boards have leaky button switch, but some of them I have seen happen that static protection component (looks like capacitor and actually another SMD capacitor in parallel) but made to channel anything higher than 3-5V to ground on the button board to go leaky. Best solution replace, not try to measure.
Oh ok. I think I understand what this is. I'm pretty sure I can't do this alone and am in the boonies without anyone to help IRL. Is there a video somewhere on how to do this? Can someone please just list the process in a 1,2,3 kind of way? Very much obliged.
How do I open the monitor? There are 2 small screws on the back bottom and that's it. I turned the whole thing around and around and no other screws are anywhere and those 2 screws unscrewed do not open the case.
We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
It's held in place with plastic clips. Use a credit card like object (don't use an actual CC, you will damage it), jam it inside the case in the area where the screws were. Then slide it across the frame and the clips will unhook. I use an expired SIM card for this purpose.
Of course you can also use a screwdriver, but using a plastic object will not leave any marks and will make it look like it's never been tampered with.
Well, nothing has worked - so I just made a video as a last plea - hopefully there'll be someone on the planet who can walk me through this and open the panel - http://www.youtube.com/watch?v=iTwFvb9T8zg
The lcd is not going to dismantle itself just by removing the 2 screws you removed, you will have to force the two parts apart.
I know - I just couldn't get to the hidden screws under that flap. I don't want to start prying anything till I know that either those screws have nothing to do with holding the screen together or that I don't need to deal with them, in which case, I'll start the prying.
CMJ21973 - Thanks for posting this - although it seems that modifications were made with my model. Much obliged for the effort. Maybe there's a 190S manual lying around somewhere on the nets. ~*~
