Hey guys I'm having trouble with this one. I received the unit having been repaired by someone else in the past. The current issue is when you apply power to the device the power LED comes on but the back-lights don't and the unit is unresponsive, you can not turn the unit off without cutting the power to it.
The power board has 7 caps: 3x330uf 25v, 1x47uf 50v, 2x820uf 25v, 1x180uf 450v.
When I opened the unit the 3x330uf caps were all swollen and the rest looked fine. I replaced all of the caps except the 180uf 250v on the board with panasonics and nichicons from digikey.
After recapping the same issue applied.
I bought a used board on ebay that was supposed to be working but i knew it wasn't going to be because it was missing the two 880uf 25v caps. I recapped this whole board except the 180uf 250v and the same issue still applies.
Power LED stays lit and power button is unresponsive even if the back-lights are not connected to the power board.
I'm thinking of replacing the controller board but would like some input before ordering one from china.
