Working time 3v3 and 5v ,but the power down time this TPS51123RGER-GP chip voltage 3v3 is 0.5 volt and 5v is 0.1v this time TPS51123RGER-GP chip is very hot.
Specify which pins are you talking about. In turned off state the SMPS does not output power, meaning that on pins 24 and 7, there should not be any output. Only outputs which are working are LDO outputs 8 and 17. What is the voltage on these pins at turned off state?
TPS51123RGER-GP Pin 8 and 17 VREG3(3D3V_AUX_S5) and VREG5(5V_AUX_S5)
these two voltage is still there , but pins 24 and 7 voltage is drop.
So you are saying that computer works sometimes for 2 min. fine before shutting down. OS boots and everything? That is strange...
Change the TPS51123 then, because it gets some feedback from the 3.3V LDO output itself. If you own a lab PSU then supply 3.3V to LDO output and see how much current it draws, maybe find something is getting hot.
Sir please give me the detailed procedure of how to check 3.3v and LDO output.
I have Dell N5110 that is not power on. No LED Blinks, No Fan Spin. When i plug the adapter to motherboard , ICH is heating too much.
Please tel me, where i have to check? with Step by sptep. Please help me on this.
