Need [BIOS dump] for a DA0HK6MB6G0 or MBX-268 Rev. G (SVE14125CLB)
    Want to confirm it's not a problem with BIOS first.
    Re: Need [BIOS dump] for a DA0HK6MB6G0 or MBX-268 Rev. G (SVE14125CLB)
    here:
    tested ok
      Thank you vvacl!
        i can't not read this file after extracted
          rename it to .bin or .rom
            Perfect. It solved my problem with the bios. Thanks for all.
              what was the problem symptom ?
              can you tell us?
                Hello dj_ricoh, I don't remember, I solved it a long time ago, thanks for the concern though.
                  I`m asking because I got 5 notebooks like yours that power up for 1-2 sec then goes off.
                  that's why I ask. ofc I don`t have bga station to reball the chipset. I only did a reflow but nothing. the weird problem is that its showing that its almost starting. bios crystal fets SIO everything show that almost start but something its shuting it down
                    dj> just check for short on powerswitched rails and u will find your problem
                      sorry I`m still learning every day.
                      what do you mean powerswitched rails? a hint? should I take coils down and see where is the short?
                      if you manage to fix one, a good hint will be to tell me what did you find bad in yours!
                        just check for shorts on big coils. mostly it is bad chip. after unsolder coil u will be for sure which side is shorted. next unsolder chip and chceck for short on pins.
                          I'm sorry, but I don't really remember, anything I do over 2 days is out of my mind.
                            tested .. good 100% working
                              Hello, i have a question... i´m new flashing bios and i see that the size of the rom is 8.4mb while the bios chip capacity is 8mb, i understand de this file contains the bios and ec data? hod do i split it so i can copy only the bios? best regards!
                                Originally posted by vvacl View Post
                                here:
                                tested ok
                                  MBX-268 with DDR will shutdown after 1 to 2 seconds. no DDR will not shutdown. I've reball HM. but the situation has not changed
                                    Thank you for this dump, it's working but i can't access bios/assist button dont work.
                                    If someone have another one please send/post it.
                                      here:
                                      tested ok
                                      hey, thank you, i solved a laptop that always start witout video, thank you very much. Greetings from Colombia
                                        here:
                                        tested ok
                                        Thank You for bios.Super worked.
