Re: Rubycon MCZ vs. SAMXON GC(M)?
VZ is not low ESR. So ESR isn't on the datasheet. You'll just need to match up ripple specs.
The SM data sheet doesn't list 8x15mm - are you sure it's that tall? If it's only 8x11.5 mm, then VZ will work fine:
http://search.digikey.com/scripts/Dk...me=493-1254-ND
Something like LXZ should be a slight upgrade from the general purpose SM, and is your closest match if it really is 8x15 mm:
http://search.digikey.com/scripts/Dk...me=565-1878-ND
