BAD CAPS AND OVERHEATED MOSFETS at GA-VM900M
    i have a GA-VM900M REV.2. bought from junkman..
    i am writing post from this board.
    there are 2 swallon and 1 broken off caps middle of the board.
    The back line of this area is red and fried.
    i changed these caps with Nichigan.
    and i realize that couple of mosfets is overheated these are near the bad caps.their name are 40TO3GH.
    i could not put my finger more than 3 seconds one, 5 seconds other.
    all of them swapped. overheat is disappear now.
    i can put my finger at least 15 seconds.
    pics will be add.
    Re: BAD CAPS AND OVERHEATED MOSFETS at GA-VM900M
    Stop!!!!! Immediately stop using those replacement caps!! They are unreputable and can do more harm than good! Also, it is never a good idea to use any electronic device with bad caps. It can kill the board dead.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      Nichigan. Is that Rulycon's brother?
        Wondering what's next. United Radio-con?
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
          maybe i couldn't do clear explanation.
          i desolder fat caps.
          changed with normal caps. value's normal.. 1000 mF.
            The problem is they are counterfeit. The good brands are Rubycon,Nichicon and Panasonic. What you have is a counterfeit copy of the Nichicon brand.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
              i don't remember the full name. maybe i'm wrong spelling
              i will control it.
              but pic are here..
                Sorry. This is nichicon..
                is this good one?
                  Nichicon is a good brand.
                  sigpic
                    The failed caps look like Toshin Kogyo ATWB or ATWY series. You should replace ALL of these capacitors. I have seen tons of them fail on 775 boards, they are very bad series, I've even seen them take out a chipset. What series nichicon caps do you have?
                      strange that they used shit caps but still put a sepc poly there!
                        ^ They do that so as to get it to outlast the warranty period. And possibly because ultra low ESR lytics have been going out of production for a while now and because polymers have much better conductivity.
                        And yes, TK's ATWY and ATWB series are egregiously bad. Worse than KZG and KZJ and only a notch above Sacon FZ/GSC.
