Good day everyone. Please I need urgent assistance concerning an HP Pavillion G6 laptop that I'm working on. The original fault was that it only powers on without the battery plugged in. If the battery is not removed, the laptop will neither power up on battery or adapter. I decided to change the IC marked PU8 on the Schematics which I downloaded. Unfortunately for me, for some not completely strange reason, my ho air gun (a Bakku 8032A with adjustable control for Temp and Air speed) didn't come up as hot as usual (later found out it was due to the low voltage from t mains). Hence I found myself having to spend more ti heating the component up as well apply more soldering past than normal. Unfortunately when I plug the board to its adapter now, it shows a dead short. The light on the adapter goes out. I've tried to locate the source o the short, but I don't seem to be able to. Everything just appears to short to ground.
Right now I Think I've hit a mental block and I need advic on what to do. I'm a tech with decent skills re soldering and electronics, but relatively new to reading schematics so please feel free in making recommendations. I've attached a copy of the schema diagram a well as actual pictures of the board. Thank you all.
