Tips for removing big LCD screens
    As I have seen on here that the new leds are going bad more and more often. I just wanted to see if anyone had tips to remove the LCD panel when replacing a led so the panel doesn't break. I have done up to 42" but even that made me weiry. I have a 50" to do and not looking forward to it
    Re: Tips for removing big LCD screens
    You would need to use the glass handling suction cups....only way
      remove t-con connections
      Place tv on its back
      Remove screws around the panel front cover ,remove cover
      Using masking tape secure LCD panel to the plastic frame in a few places to hold panel into frame
      Unclip locking tabs and remove panel with frame to safe place
      Using masking tape secure plastic diffusers together and mark alignment to back frame
      Remove diffusers to safe place
      Repair backlights etc
      Replace in reverse order
      This is how i do 55 to 60 LG
        That's what I currently do for the 42"-46". It's hard enough to lift that. I might look into some glass suction cups.
          Face down.
            https://www.aliexpress.com/item/4-su...709187199.html
            if you doing alot
              You can also prop tv at around 45* with panel pcb facing up and lift off with little stress
